Originally Posted by
Anthoop
Also do your shocks have preload spacers or adjustable collars to add preload to the springs? If the springs are weak or saggy adding preload can be an easy way to make it work within reason....of course the oil in the shock absorber is there to control the spring and the spring is there to support the weight.
I wish they had adjustable collars, but unfortunately they have spacers. I'll have to find something to measure them with in millimeters. I'll also see if my LHS has a set of springs in stock and try that out. Oil and springs would be the cheapest route but new shocks are not out of the question.
