Wm Supersport 40 Balancing
Yes, do not mount the engine where they recommend! I mounted a TT Pro .46 on mine, and mounted it so the thrust plate would be exactly where the instructions specified, but had to end up adding a little nose weight. If you balance it according to the instructions, it flies excellent.
Mike
