RCU Forums - View Single Post - Cortex Gyro with Conards
Old 06-16-2015 | 12:15 PM
BarracudaHockey's Avatar
BarracudaHockey
Plug the stuff in, do the learning sequence.
It will detect what input moves when each axis is called.
The go over everything making sure the surfaces are moving in the correct direction in relation to aircraft movements.
Start with a fairly low gain and work your way up, especially in your case since you already know how it flies without a gyro.
No issue bumping the gain with the gear down, that's exactly how I do it.
