Originally Posted by
rwijnhov
I have a 2.60m byron at6 that weights 21lbs without motor. Will the saito 60r3 be enough power for this bird, or do i need the 84r3? I would love to be able to use the 60r3 beceause of the newer tech.
The -60 flies my 26lbs FW190 OK (22x10). Your AT-6 should come out at a similar weight, given no additional nose weight.
So, you should have no problems flying it in a scale-like fashion - unless you want to also hover it..
