Originally Posted by
av8tor1977
Y
My two cents: I've never used a loop in the vent line in over 40 years of flying, and never had fuel "siphoning" problems. But that's just me.... The only time I get "crud" on my airplane is if I have my smoke system set up to pump too much smoke oil.
AV8TOR
Well when I started playing with the RC models and specifically the gassers, I put the loops on top of my tanks because that's the way everyone around here did the gas engine installs. When I put my Comp-Arf together it was much more convenient to just drop the vent line out behind the fuel tank. Trust me, there was fuel all over the belly when I landed and so I put the loop in the vent line and that siphoning went away.
So what can I say? Anecdotal evidence? Sure but it worked for me and the only models I have with smoke systems are the turbines with composite fuselages which are painted inside so when that d*mn smoke oil escapes, there isn't any exposed wood for it to soak into.....
