Thanks guys. This is actually not a 3 channel plane but a 4 channel and has a 44" wingspan so i dont know if i would call it a little glider. It will really go when you throttle up the 2100Kv brushless motor.
I did a little flying yesterday and figured out why i was flying so poorly. The rudder was reversed. Doh. Ailerons and rudder are now reversed and the elevator is normal.
Wow that made a hugh differnce in my flying. ;-) After i figured that out i was doing loops and rolls and actually landing every time without any problems.
I feel like such a dope for not figuring that out sooner. Now i just need to figure out how to change the esc to have a higher battery cut off as it is set to medium which takes the cells down to 3.15v. High will bring it up to 3.3v which i think would be better.
Thanks again for the help.
