Originally Posted by
siclick33
Are these the PRO24F-200-RT and PRO24F-200-WE? If so the product page on the website says:
However I would double check the info that came supplied with your lights.
You can get Y-Leads if you want a simple way to wire 2 lights into the beacon channel of the 4 channel controller (or you can make one yourself).
http://www.unilight.at/shop/eu/addon/cables/y-cable.php
Yes, those are the lights I am using. I saw the Y connector listed on Unilights website. So, I guess from your answer, there is no way to program the controller for 2 of the 4 channels to work like a single beacon? My shop does not have anything this small so I'll give my LHS a try before throwing in the towel for the unilight Y.
