May I add my two cents?
One can get away without siphoning of fuel (without the loop) while in flight if the vento face is facing forward and in to the airstream. But not when the model is static and you turn the model upside down for some reason.
Have one set up with the brass pipe at the end of line facing forward and one with the loop. Hence can speak for both setups
