Is anyone using the new APS 380 RX fuel pump on the Moki 250's? I just replaced my 380HV pump with the newer RX version. Looks like you can set up on a throttle curve. just curious if anyone if setting the pump at a fixed % fuel rate or using a curve mixed with throttle.. if so, what type of settings are you using?
