Originally Posted by
codiddley
I finally got a chance to maiden my 1/3 Barth Waco YMF-5 last weekend at an event I organize. I replaced the old Brison 6.4 with a DA-150, and installed some 8411 servo's in the tail. I have them mounted to direct drive the elevator halves. This was built by a gentleman who only flew it once or twice, and then passed. It was bought at an estate sale, then re sold to me. I drove two thousand miles to pick it up, and have spent the last year making it flyable.
I set the firewall with 3 degrees of right thrust, and about 3/4 degree of down. After initial trimming, it could use a skootch more right thrust, but that is easily correctable with some rudder input on long up lines. Field assembly took just over an hour for myself and a friend. After a couple flights fittings and flying wire moorings began to loosen up. Some loctite seems to have helped.
I must say, it both flies like a heavy warbird, and a super cub at the same time! You definitely feel the weight of the airframe in the air, but it carries it's energy well for hammerheads and deadstick practice. I did loops, rolls, hammerheads, knife edge passes, inverted flight, barel rolls, and tried one snap at the top of a loop. It was a failure, and with a 20+ year old model I don't want to break it in the air! Or anywhere for that matter....
What are you guys doing for wingbags? I'm thinking about making a PVC and pool noodle wing rack, but would love an enclosed square briefcase style wingbag with at least 5 slots for the wings, N struts, and flying wires...
Here is what my bird looks like-
Congratulations on the maiden glad all went well. I to am looking for some affordable wing bags let me know if you find some.
