Originally Posted by
wfield0455
For the gyro function all you really need is 3 unique switch positions. You can assign switch SD in Function Assignment and usiing values of 100/0/-100 should be fine.
Next go to Fine Tuning, Gyro settings, which should be available if you set "Use Gyro 1" to "Yes". In Gyro settings, select the switch position you want the gyro to be "off" and dial in a gain of 0, Next select the center switch position and dial in the desired gain (+50%), Final select the third switch position and dial in your -50% value.
If you want to be able to adgust the gain for the active switch positions, select one of the knobs in the tuning field and assign a percentage in the gyro sense field. By selecting the proper values, you can have knob p8, adjust the gain for the Cortex normal mode from 0 to assigned gain value and p7 do the same for the hold mode..
Thanks again Wayne, got it at last....
cheers,
