Sometimes their will only be an S or SS and not the entire "Syncro spark " scribbed into the case near the date . Brisons will also bite if they are too lean on the low needle and have the throttle open too far , or flooded (odd right!!!)
If you verify that you do have a synchro ignition I would recheck the fixed timing again and be sure you are setting with a counter clockwise rotation of the crankshaft. If all else fails to resolve the issue replace the p/u sensor I have had them cause your concern but it is rare . Usually the sensors just completely fail. The usual cause is an open high tension lead by the spark plug cap being off the plug while operating the ignition.
Keep us posted
