Hello friends, I end up using 3 pound weight, with a DEL61cc using electric Robarts. Is that sounds right to you??
What about the factory CG, it’s OK for flight or maybea nose heavy for start testing??
For the Robart electric mains retracts, the strutsneed to be file flat where the two clamping bolts in the retract adjust them?? Inorder to prevent the strut stars rotating??
Best regards
Erwin
