Originally Posted by
RustedRC
The servo does hit the battery tray when the suspension flexes but you can get creative and do something like make some extensions for under the tray. maybe take a pen apart and cut it to raise the tray up a bit or something similar. i had that problem so i made a battery tray from some sheet metal. it holds all my electronics up front radio box, ESC, wireless winch controller and the battery. i have my battery sitting length wise behind the front tires. helps to keep the COG lower.
i was going to install spacers under the front battery tray, but sideways might be a better idea behind the front tires because the battery can sit lower and not be in a way of the front servo, ill have to play with it a little more. I upgraded my transmission gears to metal, but my large pinion gear broke a tooth so i ended up buying 2 more of those, will have to swap out. Some wheels and tires are on order also
