Originally Posted by
Lifer
Plus one on the metal pushrods. No longer an issue.
Just asking, but did you remove the spring and the ball-bearing detent from the carb body?
Hi Lifer
Are you referring the spring and screw connected to the Throttle body and throttle linkage, Then Yes I did. Is there anything in the Choke internally that will remove some of the stiffness?
Using basically 2 metal rods connected with a 2 " section of Yellow NY-Rod inner tube to keep it as stiff as possible while breaking up the metal on metal continuity. Overall the length is 14 inches.
Ed
