You can remove the screw that attaches the butterfly to the bar. Note exactly and mark the position of the butterfly before you remove it. After doing so carefully move the mounting bar, there is a very small ball that is spring loaded that will fly out , watch your eyes, This will release the tension, replace the butterfly, now the choke will move as easy as the throttle. Hope this helps.
