Originally Posted by
Lifer
Plus one on the metal pushrods. No longer an issue.
Just asking, but did you remove the spring and the ball-bearing detent from the carb body?
Hi Guys,
Thanks to Dan, Lifer & JMpups,
I figured it out. I enclosed a pic because I know everyone loves pics. I was able to remove the ball & Spring that was placing undue pressure on the Choke. With a servo controlling the Choke there is absolutely no need that I can see why it needed. I was able to remove it and now the choke linkage works flawlessly.
Thanks again for you guys that helped with positive info.
Ed
