Originally Posted by
All Day Dan
You may have damaged the threads in the shaft when you removed the screw if you did not grind off the end of the screw first. Dan
Dan
What do you mean by grinding off the end of the screw? The screw came out pretty easy. As easy as one would expect a screw with Loctite to be removed would be I had no issues screwing it back together other then a slightly stiff. I made sure not to cross thread it and made sure the butterfly plate lined up just right before snugging it down.
Ed
