Maybe the problem with the ARF's covering is that the wood is still full of moisture from Vietnam. It is super low humidity here (like 15%) and the black covering absorbs more heat than the white. The moisture gets baked out of the wood in the hot dry air, the black sags and loosens up (the white stays tight). Maybe eventually the thing will acclimate itself to this dry climate and stop shrinking.
