RCU Forums - View Single Post - nitro rustler problems
Old 10-16-2003 | 10:27 AM
Nitroaddict's Avatar
Nitroaddict
Default RE: nitro rustler problems
ORIGINAL: Mavericman
i have that sam problem, if 1. i try to ease on the gas it bogs down. what should i do with the low speed needle? 2. also after i let off the gas the rpms slowly rise then fall then 3. if i dont give it some gas, it stalls. ive tried adjusting my idle but either the rpms are too high that the wheels turn or the idle is too low that it shuts off. maybe if i get the low speed needle adjusted in synch withe the idle it will work. what do you think?
1. this could be caused by either over rich or over lean settings. over rich will cause a gurgling sound. over lean will cause a hiccip sound.
2. This is ALWAYS caused by an over lean needle setting.
3. This is also caused by an over lean setting, the engine is stalling when u arnt giving it gas, because it is starving for fuel
