Restrictor will only slow the flow of the air going to the brakes slightly, it will still build up to the same pressure and lock the wheels, just may take a second longer to happen. I would be either find a pressure that works well with your brakes, review the brake mechanics to see why they are grabbing, or depending on wheel brand; lightly lube the brake hub with O-Lube.
