RCU Forums - View Single Post - New android based telemetry system for our jets (and other flying things :)
Old 07-02-2015 | 11:05 AM
  #87
Chris Smith's Avatar
Chris Smith
Originally Posted by Carsten Groen
Still waiting for some info from them
Something new regarding the telemetry, now it is possible to connect to a small "Bluetooth gateway" I have running. That means that you no longer need to have the small radio module connected to the phone via the USB port !
The idea is then to have the BT gateway with reach of yourself when flying (max distance around 15 meters or so), it will then relay the live data from the plane to your phone !
Carsten,
Do you have any Gateway suggestions? There are quite a few bluetooth gateways out there. Probably depends on the CAN-RF connector correct?
By-the-way, has anyone confirmed JetCat V5.0 ECU compatibility with the ASSI yet?
Chris
