I got around to making my tail wheel assembly. A couple of bad practice turns in the 3/32" music wire. Figured out what it needed. Then I made the tail wheel assembly. Second picture is rough install. Last picture, picture not too good, is final install with pivot tube CA'ed in place. I will add epoxy later. Wheel is under pivot tube and turns super easy. It should work good. I will cut wire stock when vertical fin is in place and I can check it against rudder.
Next week I will do the final painting. Nothing fancy. Just good colors for weak eyes.
