Originally Posted by
vertical grimmace
Sid, I will cycle the battery. I am not here to bash the Jeti, just trying to find a solution. I really do like the radio. But I have to say, the feel of the entire flight was really "loose". I could not get the plane to stay trimmed. Which is not a problem with this plane either. The control felt "pixilated" if that makes any sense. Very course, like a low resolution. Something was not right. Maybe the RX was not bound properly?
I am sorry to hear that, but you DO NOT have to speculate, all the tools you will ever NEED you have right in your hands.
Transmitter has full telemetry, it will tell you Rx Voltage, Signal Strength & Signal Quality. It will log all the data, simply you have to learn how to utilized this great tool you have at your disposal.
1) Battery Voltage Alarm
2) Telemetry Low Voltage RX
3) Data logging
The R6L is fine, there is nothing like improperly bound. You can display A1 , A2 & Q antennas right on the display.
You have to understand something, never before we had all the options. No more guessing, simply you know what went wrong.
Zb/Jeti USA
