Originally Posted by
vertical grimmace
This airplane flew with no problems the last 1.5 years with the only change being the Jeti RX for this flight. So yes, all of the installed equipment was compatible and working perfectly. Maybe that Jeti 6R light RX was not acceptable for my application? I think it was more TX than anything else.
The A123 I use are from Valley View RC. I have them in around 8 airplanes now, and have had zero problems with them so far.
What servos were being used in the airplane? If they were analog servos, did you leave the frame rate set (set in the receive via device explorer) at the default 17ms or change it to Auto? If the airplane was using analog servos the frame rate needs to be left at 17ms, for digital servos, either 17ms or auto would be fine. JUSt one more thing to check...
