The bad thing about detonation is that it is aggravated by high temperature and high loads. On a cool day, you may be fine. Second, you may never hear it. Even 2 to 3 degrees too much timing advance can cause detonation (pre-ignition) damage. I'll put money on the timing was too advanced when the OP re-installed the pick-up.
