As far as I remember, the ailerons were the function that seemed to be acting up.
On another note though, I did cyle my battery and and it only took 200 mah out on the discharge and then only charged up to 300 mah. Which seems odd. Maybe I did not do the cycle properly, or the battery is bad. On the next subsequent cycle, it took it up to 900mah. As I wanted to try it again. I had it plugged in to balance. I am trying another known good battery to see how it does. 200 mah is getting low for sure on a battery of 2300 mah capacity. At this time, I will admit that I think it very well could have been my battery. Even though the volts were still up, the amps were very low.
