glue for hinge pins
Ok all of you great builders a question.
After doing the repairs and glassing on my G/S Corsair I am ready to reinstall the hinges (Robart large hinge pins) in the past I have used gorilla glue the expanding type, but don't like the clean up that uses out I would try 30min epoxy but don't see a good way to get the stuff in the hole. I made a test board drilled the holes to get a good fit and tried to wipe the epoxy into the hole with a slimed down Q-tip, and some on the shaft, seams to work but the hinge shaft is still a bit lose right at the exit point.
So I am open for some suggestions
Thanks in advance
Cheers Bob T
