Originally Posted by
vertical grimmace
In the Ds 16 the screen shows 4 items, on the Ds 14 it only shows 2. Data logging can be added as an upgrade on the DS 14
The real question is does the DS14 still record a log file but you need to order the upgrade to view it on the transmitter or does it not record the log file at all. From the main menu, do you see a square in the box next to where the flight mode gets displayed and is there a Start button? If there is a Start button and the square turns into a flashing dot when it's pressed, it's recording a log file. If it does record the log file you should be able to connect the DS14 to a PC and find the log file in the Log directory and then view it with Data Explorer on the PC which can be downloaded for free..
