I have used the gorilla glue with good success but you need very little. I dampen the hole with a wet q tip and then use a tooth pick with a drop of glue on it and stick in the hole then put in the hinge. Using a drop of light oil on the hinge joint and then leave it alone until it expands. After it drys it is very easy to pick any excess off with the tip of a #11 blade. Lately I have used the gel epoxy made by PC7 it stays in place and you need very little if your holes are not to big.
