RCU Forums - View Single Post - small gas engines
Old 07-07-2015 | 06:49 AM
captinjohn
Originally Posted by geeter
i never said i didn't like gas engines......i do like them however i can't see why the factory doesn't make them to run better. i see threads where people are changing mufflers on them, drilling holes in the muffs, adding bigger pressure taps, changing carbs, changing carb parts even trying nitro carbs on them. just make them so they run good and i would buy one it's just all these threads are confusing sometimes. maybe i should stop reading them .......huh.
It sounds like you need to get out with people that fly small gas powered airplanes. Do you have any friends? Like to help you understand what you need to know????? Other than that go & disappear from gas forums..........
