RCU Forums - View Single Post - glue for hinge pins
Old 07-07-2015 | 01:57 PM
SunDevilPilot's Avatar
SunDevilPilot
I too use 30 minute epoxy. I also use the cone shaped dremel stone to taper the hole. I put epoxy in the hole, smear some on the barbs only, then use a clean q-tip to remove any epoxy near the knuckle. Then install the hinge.
