RCU Forums - View Single Post - Modeltech Cap-21 arc
Old 07-11-2015 | 11:15 AM
leojzamboni's Avatar
leojzamboni
Erez,
I had already read your article "A simple CAP 21". In fact, I have it as a reference, and it helped me to decide buying this model, so now I have the opportunity to thank you. Mine is the same model as yours and, of course, I'll try to keep it as simple as possible. I'll certainly follow some of your construction tips, like the pull pull system for the rudder. I will install a 55ax, which I believe will deliver more than enough power without beefing it up. I'll have to keep the wood cowl cause it is not easy to find a fiberglass replacement here in Brazil. Not sure yet if using two servos for the ailerons is a good mod, I don't like the idea of digging the wing foam. What do you think?
Regards,
Leonardo
