RCU Forums - View Single Post - Foam wing cores
Old 10-16-2003 | 03:42 PM
Ed Smith
Default RE: Foam wing cores
Lets see if I can explain this without a diagram.
when the root template is in place measure from the top of the foam block to the top of the airfoil template high point. When placing the tip template on the block use that measurement to position the template, ensuring at the same time that the airfoil centre line is parrallel to the root template centreline.
Ed S
