Originally Posted by
luv2flyrc
I have it set for 3x. I assumed that is the number of times in a row it repeats the warning?
I don't have an Activation Switch selected, I assumed that would leave it "always" active. Is that the issue?
Mike.. I have an Mbar, but I have not tested repeatable alarm issue. I "guess" that there is a logic in the programming that once an alarm has been triggered (once or 3X) and user has been notified it will not alarm again to avoid "annoyance"... Until a power cycle..
I have mine set with the retract switch as the activating switch for the alarm.. So the alarm is only active in the retract position. That's the only position I care for the amount of on board air pressure...
Enjoy..
David
