Originally Posted by
LA jetguy
Mike.. I have an Mbar, but I have not tested repeatable alarm issue. I "guess" that there is a logic in the programming that once an alarm has been triggered (once or 3X) and user has been notified it will not alarm again to avoid "annoyance"... Until a power cycle..
I have mine set with the retract switch as the activating switch for the alarm.. So the alarm is only active in the retract position. That's the only position I care for the amount of on board air pressure...
Enjoy..
David
Thanks David
Yes, it seems that the only way to reset the alarm is a power cycle of the Tx unless I'm missing something. The set up appears to be quite simple though.
Mike
