Originally Posted by
nesan
Good catch there could be carbon in the engine. the engine is not used for over 30 years.it was not turning when I had it , Then I socked in diesel for over 2 to 3 days.
where should I clean the carbon? over the piston and contra piston is enough or should I remove the crank case as well?
I would suggest that someone more experienced than me guide you on this one - Ray ...... you there mate?
