Originally Posted by
nesan
the Propeller I have tried APS 13x6 and Master air screw 11X8. the 11x8 is little better.
I have other P.A.W engines like PAW09 TBR, PAW100TBR, PAW249. all running well without a hitch.
If that fuel works ok in your other PAWS then it's fine in this engine.
Those props are quite a way towards being an excessive load for my tastes. I use a Master 11" x 5" on my similar PAW 35 in a Ringmaster.
Can you trim your APS 13x6 down to say a 10.75" diameter?
Other than that I can't see too much wrong. Carbon on the piston might take a few 100's RPM off the top end of the range, but I don't think that it's your problem.
