This is a common issue with the Pershing.
The compartment is so tight that adding the battery usually creates a problem closing the hull fully.
Some creative "sweet spot" adjustment of the battery will solve this, even so still tight.
On solution some have done is to shorten the speaker box or leave a cutout for the battery to slide into for added room closing the hull.
