RCU Forums - View Single Post - Is it possible to convert smaller OS glow engines (60-91) to gas?
Old 07-16-2015 | 11:50 AM
Sport_Pilot's Avatar
Sport_Pilot
The low end on the glow engines ,will not hold up very well long term
The original gas engines made in the 30's and 40's were cruder than the bottom end of our glow engines. They will hold up fine if you have enough oil, I believe that to be 10% or 1:9 ratio or higher. Cost is cheap, Put in a gas glow plug and experiment with adding methanol. Don't bother with the carb if you don't want to. Adding methanol improves the power and mitigates the carb issue.
