Originally Posted by
Jeti USA
Hey we just got another revolutionary update from Jeti. You can use R3/RSW as RF Module for ANY other radios system.
Email me for the software at
[email protected]
Next week we will add it to standard Jeti Firmware Update page.
Zb/Jeti USA
Described firmware for the Duplex R3/RSW (R3L) receivers allows you to
use the receiver as a full-featured and standalone Tx module.
The firmware is compatible with the “EN 300 328 v1.8.1“
standard.
With this update you will be able to simply use a wireless
Teacher/Student function (“buddy box”) together with any
third-party transmitters. You only need to supply the R3L with
power and PPM signal through the trainer port of the student’s
transmitter. After that, you should switch the DC/DS transmitter
to the “Teacher” mode and bind in a usual way.
The behavior of the R3L receiver in the transmit mode is completely identical to the Duplex Tx modules.
Zb,
This is actually VERY cool. I have been trying to help some guys with FPV goggles get their head tracking to work with the Jeti and I THINK this should be just the ticket. It would seem that if they connected the FPV head tracker goggles PPM output signal to the PPM input that the R3 now has with this new firmware, that they should be able to connect to their DS16 now via the trainer function and with the correct setup, their head tracker should work.
