RE: THROTTLE CURVE
Use a very short servo arm and lengthen the throttle arm. You may hve to add a piece to the arm. Use a 2-56 bolt and some JB weld if you need to. Make sure the servo is full forward at off, pointing at the throttle, and it will help the geometry also.
Bean
