Originally Posted by
qazimoto
So we don't quite know if the lighter propeller load or the new fuel batch actually solved the problem.
Can you give the PAW another run on the old prop with the new fuel and report back?
Hello I have already got the video with big prop first thing in the morning. no time to up load right away so I do now.
all the things you guys share me is valuable and I got some good studies from this ideas. first of all "Qazimoto" propeller suggestion put the paw 35 to closed to the peak bhp band around "12000rpm" with his suggestion the engine went up to 9233 RPM.
I really wanted to find out the answer for the same question you ask here is it prop or fuel. here is the video. in next post I will share my findings of fuel I tried since last month.
first propeller master air screw 10.75x6 reach upto 9230 RPM
engine stop as I close the needle
second propeller APS 13x8 reach up to 7100 RPM
engine stop as the fuel is empty
I will never quit guys I will go up to end ask me if I can do any other test
http://youtu.be/_g2TYlarL7E
