Originally Posted by
Jeti USA
Hey we just got another revolutionary update from Jeti. You can use R3/RSW as RF Module for ANY other radios system.
Email me for the software at
[email protected]
Next week we will add it to standard Jeti Firmware Update page.
Zb/Jeti USA
Described firmware for the Duplex R3/RSW (R3L) receivers allows you to
use the receiver as a full-featured and standalone Tx module.
The firmware is compatible with the “EN 300 328 v1.8.1“
standard.
With this update you will be able to simply use a wireless
Teacher/Student function (“buddy box”) together with any
third-party transmitters. You only need to supply the R3L with
power and PPM signal through the trainer port of the student’s
transmitter. After that, you should switch the DC/DS transmitter
to the “Teacher” mode and bind in a usual way.
The behavior of the R3L receiver in the transmit mode is completely identical to the Duplex Tx modules.
Hi ZB,
Do you know if this capability will be made available through firmware update sometime in the future for all EX receivers?
tks,
Leon
