Originally Posted by
Blancr
Thanks Jeti USA - I can now see both bats and antenna and I have 2 rsat2s in EX mode. Just a point of clarification: - having followed the video, I can't see the PB on the jeti screen. Is this because it's 'not Jeti'? Otherwise everything seems to be working ok.
Thanks again for the help
Bob
Bob,
only native Jeti devices will show up in device explorer, no PB products. Everything should be fine if you see both RX in device explorer and both receiver "dots" on the PB display. You can easily test your system by disconnecting one receiver, everything should still work normal.
If you connect the PB telemetry output to the EXT input of one of your receivers, you can even get full telemetry like indepent battery & antenna fades/holds info. But in this case you would have to connect the receivers to the PB box via the SAT port to free up the EXT port (that requires to set the Jeti serial output to UDI and the PB box to accept UDI in)
Thomas
