Originally Posted by
psb667
Cessna 02
WOW!!!! I expected this one to go quickly, but not quite this quick. I tried to space out the clues to make it a bit deceptive at the start. I thought it would go a bit longer than the first 2 clues. Wow!!!
But psb667 is indeed the man. He has is the winner!!!!
1. Warbird developed from civlian aircraft
2. Plane is a single winged aircraft
3. Twin engine aircraft
4. 2 primary variants built
5. Primary customer was for an Air Force customer but several were transferred to the owning countries naval operations.
6. Plane was maintained for a night mission role
7. Plane was used for a phychological operations role
8. First produced in 1967
9. Primary intial customers were US Forces.
10. Later aircraft transferred to Vietnam forces.
11. Engines mounted on the centerline of the fuselage of the aircraft
12. Engines mounted in a push-pull configuration which allowed for a high wing clear observation setup.
14. Later life use of the plane included use in naval strike squadrons.
Cessna O-2 Skymaster
PSB667 Your're up.
Ken
