One more question. This thing caN glide forever. I was thinking of setting up the three way switch om my Turnigy TGY-i6 to do both flapperons and spoilerons. Found the info to set it up like that. Only problem is that the ailerons are in a y harness and the wings glued in.
I could cut a hole in the bottom of the fuselage and change out the wiring, but do you think it would be worth it? I think it would definitely help to get this thing down in tighter spaces.
Also how would the ailerons get hooked into the receiver then? Use channel 6 for either L or R and keep the other where the Y harness is plugged in?
