Originally Posted by
ETpilot
I remembered the 3 memory holds. It may have something to do with the memory. .
I,ve never felt the need to remove the battery but rather make darn sure the thing is off. Yes its a pain and it would have been more to my liking without those memories.
The procedure assuming you have select your prop blades is: single push of the left button and it is on you can now use it like any other tach and to shut off as you lay it down is make four button pushes of the left button to shut off. not three but four button pushs for complete shut off. Its just too easy to just push it once and move on but that puts you in the one of the three memories and still on.
John
