Standard right hand threads. I would probably remove the prop hub and check things out. You might have to heat it a bit to get it started unscrewing, but Don't get crazy with the heat as there is a rubber seal behind the front bearing.
You could also easily pull the back cover off and inspect the rear bearing. Those are the only two things that could cause your problem.
