Hinge Choice For Senior Telemaster
Unless there is something very different about the TM,suggest you do a search under hinges,and you will find the subject exhausted many times over.It comes down to opinions on flat vs pin type,glue type,whether to pin flat hinges or not,etc etc etc .I like Robarts,many prefer flat....just make sure the hinges are anchored well,installed carefully,and that you use one big enough for the model and enough of them.
